Old Aug 22, 2021 | 09:34 AM
zip439's Avatar
zip439
Default Re: Worth replacing new Pirelli P Zero for an increased aspect ratio?
Originally Posted by kowaltoboggan
Sorry. Meant to address this as well as I didn’t explain that. As it is a used car, I priced out the problems I saw (from photos) and used that in the negotiation process. Had they not been lazy and looked into the "bubbled clearcoat" they would have noticed the issue was better than they thought as it was excellent paintwork covered by VPS. They put the tires on within the past two months. Had I been able to see it in person I would have made a stink about it. And I didn't think to ask them to verify the tire sizes they put on. I had been asking lots of other questions, but didn't expect a dealer to fit the wrong size tire. Mea culpa.
You may want to keep the "VPS" as the front of the Crossfire takes a beating and will chip paint for certain when traveling on roadways. VPS does a much better job at protecting from gravel and sand grit than ceramic. Have a detailer remove the bubble, but leave the vinyl protective film or replace it in kind.
