Old Aug 26, 2021 | 07:01 PM
GraphiteGhost
Default Re: Battery Dischare Rapidly with ignition off
Originally Posted by blacktouring
2005 Touring. In Nov. '20 I had my RCM overhauled. I worry that my RCM may have failed again grounding my battery. Of course, it might be a different problem. My battery is completely discharged in 36 hours.
Help will be hard to give with what you posted. Member Bill F has a starting point but be aware many places have idiots for technicians in regards to battery viability. When was the battery installed? Some say replace after 4 years with a quality replacement. IF your battery is 5 or more years old then suspect a test as erroneous if it indicated good. There is a help forum post for a systemic test of system current draw outside of the normal (with a good battery). After you eliminate a bad battery you may wish to familiar yourself with that testing procedure. Good luck!
