Update: I checked the actual battery drain after letting it sit all day. I have 0 voltage drop and it shows a draw of 0.01 AMPS or 10 milliamps or less if I let it sit a little while. I'd say that is pretty good considering when I started this quest to fix the issue the battery would die within 2 to 3 hours.
@CaptainHero I pulled fuse 35 to test/compare for you but it did not make any difference. My clock, temperature etc.. stays on for about 30 seconds after the car is off then it all shuts off. When that stuff is on for that 30 seconds my draw is 0.1 AMPS then after it shuts off it drops to .01 AMPS.
