Old Sep 1, 2021 | 08:19 PM
onehundred80
Default Re: Can’t turn key in ignition cylinder
Originally Posted by Toolman
Check out the TSB's and How To Articles section of the forum. There is a Sticky for the Ignition Key Fix.
You do not need to break the assembly the stuck pin can be drilled out, however, that is additional labor time the dealership would charge you, and they may not be willing to do that as it disables the steering wheel lock in place function. I did it on my 04 Crossfire and I do not miss it.
You can also use the search function to find many more related threads.
I did the mods and the steering wheel still locks.
