try this one
https://vtech.ge/en/
vtech georgia they are the one that fabricate the fixed pulley for m112k
you should wire a relay with an led stripe in the pillar or any other setup, so it tells you if your ecu send signal of supercharger disengagment for protection
and put a 1/4 spacer on the bolt between the smog tube and power steering reservoir, so the oem pulley washer doesnt scrap the aluminum tubes
