Old Sep 4, 2021 | 12:07 AM
Spector01's Avatar
Spector01
Default Re: Convertible window repair
I left primer on for a day before window weld. No problem. Anyone have an idea for a solvent for window weld? I did not do as good job this last time. Acetone will work. Worried it will damage top. Naptha will work but same concern..Painters solvent did nothing.
Once it is dry really hard to remove and I needed Xanax after using a razor to remove most of it. It did try to make it less noticable by putting a little black spray paint on with a brush and that actually softened the window weld. It was cheap quick dry stuff and melted the red Solo cup i sprayed it in so I could brush it on so thinking acetone was the solvent.
