Old Sep 4, 2021 | 09:01 AM
Daveace's Avatar
Daveace
Default Re: Antenna Gasket Replacement
Remove trunk lining, remove rear light 3 x 8mm nuts disconnect harness to light, 22mm socket to remove base nut, disconnect antena wire fit new gasket replace in reverse order the original gasket part no is A193 820 05 89 IN CASE YOU WANT THE REAL THING Hardest part is disconnecting the back light harness and putting lining back on.
