Old Sep 10, 2021 | 06:37 PM
onehundred80
Default Re: Hello, new Crossfire owner, make sure to check your air box!
Originally Posted by SD Crossfire
Absolutely, ……….I also noticed the coolant is green instead of blue, so will likely need to attend to that as well.
The original antifreeze is blue, the Zerex G05 is yellow, draining the original blue leaves some still in the system and adding the Zerex gives you a greenish fluid. But change it anyway as the wrong fluid harms the engine block material slowly.
