Thread: Interior Lights
Old Sep 11, 2021 | 03:35 PM
GraphiteGhost
Default Re: Interior Lights
Originally Posted by BoB Fenn
Hi Guys... has anyone experienced an issue with the interior lights NOT working suddenly? They used to come on when I opened the door, then dimmed slowly after I closed it, or if I was just getting in, they would come on, and then dim slowly once I was in and closed the door. This feature just stopped working, but the map light feature DOES work, so the bulbs are fine... since the headlamps also used to stay on for a while after I locked it, and that ALSO stopped, I am guessing they are "related" issues. I did have an issue with the security system because of the frequent water collection in the trunk area and in my case it corroded off one of the connectors, but I was able to purchase an entire harness and "brain" from which I transferred the good connector over from and I've had NO issues with that system since. Anyone dealt with these issues? Thanks as always! BoB in Mass.
Hi Bob, just a FYI and a Q? Is the selector switch on the top center console (dome light housing) in the correct position? No sure if it matters but maybe it was accidentally switched? Hope it helps.
