Some forum members have reported having cracked climate control *****. If you look on ebay you will see many used climate control assemblies for $150+ that already have cracked ***** like the one below.
I decided to buy a climate control assembly both as a spare, and to have spare *****. The ***** look good on the outside, but I found on the back that one **** had a crack starting, but it had not gone far enough yet to split the face of the ****.
My first thought was to put a spring metal ring around the outside of the **** shaft, but it's oblong and that wouldn't work. I decided to epoxy the shaft adding thread reinforcement wrapped around it. I used a strong upholstery thread and super glued the the first loop knot to the shaft.
I mixed up some J-B Weld original formula and applied it to the **** shaft. I then wrapped the shaft with the thread and covered that with a little more epoxy. I added a little bit of epoxy down at the base where the cracks would split out onto the face surface of the ****.
I plan to do all my Crossfire ***** to protect them.
Items used:
JB Weld Original Cold Weld Reinforced
Coats and Clark Extra Strong Upholstery Thread
Aluminum Tube (1/16 size for wrapping thread around **** shaft)
