CaptainHero
It sounds like you don’t have the same problem but instead a very different problem. Your problem sounds much more like a battery drain issue if you have to have it jumped and have replaced the battery more than once. If it starts when jumped you would likely need to track down what is draining the battery. There are multiple threads detailing how this procedure is done with a couple currently going through it or having recently solved their issue. There are various causes which all result in a dead battery so testing and narrowing it down to a specific fuse seems the best course of action.
Thank you for taking time to help, much appreciation😊
