Old Sep 15, 2021 | 02:40 PM
GraphiteGhost
Default Re: Panel Under Interior Ignition
Originally Posted by Scott M
This diagram may help you to identify the correct part for your ebay search.
And when you click on the provided link, select one of the part numbers (part list 19, three of 3), and under the new page you can click on a link there and enter your car VIN and such (I believe 3 or 4 items but the VIN might be enough) THEN it should tell you if that part number is the right color. If it is not, go back to the parts page and select the second part number and do the same (and if not) select the last part number and it should be the right color (to help with your part number lookup) I believe after you remove that panel, the part number should also be stamped or labeled somewhere on that part. Good luck!
