defazioanthony
I bought a set of LEDS low beams. I got the driver side done and works fine. I repeated same process on passenger side. But now after I unplugged the light it will not work. I tried putting regular one in and now it doesn’t work at all either. Any bulb does not work. Any answers on why it does not work after unplugging it??
Do any of the passenger side lights work? If no, then you more than likely had a fuse blow. Each side of the car has a fuse for all the exterior the lights. Happened to me when I changed the side marker light.
