Thread: Azenis fk510
Old Sep 26, 2021 | 11:57 AM
GraphiteGhost
Default Re: Azenis fk510
Originally Posted by Troutkill
So yes the aftermarket wheels and Tires had spacers and they used the spacers on the factory wheels and tires too. The set that was on the car (aftermarket) were not very smooth, flat spots on the tires from sitting for almost a year.. (250 total miles)
the factory wheels and tires are alot smoother under 70 and then all hell breakes loose. I don't know what lug nuts I need., I have several..
I know I have a mess on my hands. Thanks I will update when I get things figured out
Just as in a problem with spacers, you need to make sure your using the correct lug bolts and make sure the length of them isn't too long or too short. Again, you can tear up a set of rims (as a minimum) not having the right fitment of aftermarket wheels to hub & lug bolts to rims/hub. Good luck!
