Old Sep 27, 2021 | 08:57 PM
extremekustoms's Avatar
extremekustoms
Default Re: Intercooler upgrade
New to me used intercooler leaks bad at 10psi
My old intercooler has a very tiny leak and can not see it even at 40psi but it was sure dirty
Old intercooler was leaking as there is some fresh thick brownish coolant inside the Y pipe
After cleaning & flushing a few time i stood the intercooler up on its outlet with 40psi for more then a few hours and this thick brown crap came out but sill only has a very tiny leak this is almost impossable to see
On the inside of this fitting you can see some of the thick gel that came out the first time i flushed it. Thinking past owner used a rad sealer to stop the leak and when i flushed the whole system to install a new radiator it opened up the leak
