velociabstract
My advice is to separate the intercooler from the cooling system and run straight water, or with water wetter, through your barely leaking intercooler. The leak wont hurt a thing and may even make it run a degree cooler. Plain water won't leave a residue like the coolant and will even help keep the valves and combustion chamber cleaner than without the water.
I'm serious. Not joking.
Les
Yeap i have seriously been thinking the same and use windshield washer fluid as the cheap & easy to get coolant the 35 to 40% meth stuff but i need to get this car smogged first so might put an simple gate vale in the intercooler lines to stop the flow and that should help
