Re: The Chevy Vega - '74 GT
~ Cluster is mounted, dash pad is mounted, must remove glove box to install sissy strap to the dash pad.
~ Painted the side mirrors and headlight bezels 08 Dodge Brilliant Crystal Pearl Black. Moved the Crossfires to avoid overspray.
~ Wet sanded all overspray from door jambs. Fabricated a new clutch linkage from pedal to piston...it bent from offset angle.
~ Made a test sprayout of the Mazda 46V Soul Crystal Red- 4 stage with the black stripe...close but no cigar...I don't think I sprayed enough base coat...will try again.
