Re: Heat exchanger upgrade / Cooling mod
I hope your KC works well with the MB A/C supporting system for you and i will be following your results as i like the idea. I started to build an a/c cooler already but put it aside when the Fords Gt 350 A/C system did not do a good supporting job. He lost 2
ac pumps in 4 months mostly freeway driven commuting 40 miles to & from work but it was hot here at the time mostly around 100f. Also like the idea of an extra large reservoir tank with an large opening so you can install fairly larger chunks of ice (Frozen water bottles) as they last much longer than store crushed ice.
