Old Sep 21, 2006 | 08:03 AM
  #376 (permalink)
danimal's Avatar
danimal
Default Re: Sprint Booster - A "Must-have"!
Originally Posted by Bif Powell
I have to check mine out again because when I turn the wheel lock to lock, something in there is taping/touching the extra cable. Have to do something with that - any tricks/suggestions, or just let it hang in there and hope it's all good?
Bif, I agree with Timelord...it sounds as though you may not have gotten the pin/peg back into the upper support bracket. When I put the pedal back on and started to tighten it down, something didn't look quite right, and that is exactly what I had done...did not get the peg in the bracket. If you push up on the thin plastic cover just above the pedals you will be able to see the bracket.
