Old Oct 11, 2021 | 06:50 PM
ala_xfire
Default Re: Coolant light on-radiator fan NOT spinning
Originally Posted by BettyNVeronica
I had put in a new FCM. It's a new fan and should work. Is there a way to check fan outside of the car?
You could hook a wire pair into the big fan connector and run it up to the cowl with a 12V light bulb.
another way to command the fan on to warp speed is to pull the RCM and put some paper between the engine relay contacts.
turn the key on to just before start and wait. ( or I suppose you could just pull the small yellow fuse )
The one in the middle
