Old Oct 12, 2021 | 07:40 PM
Jack G's Avatar
Jack G
Default Multifunction Turn Signal Switch Replacement
I am presently in the middle of the process of replacing the steering column multifunction switch. I am at the point of trying to remove the existing switch and experiencing difficulty. The 3 screws holding the switch assembly and the cruise control have been removed. I need some guidance with how to remove the multifunction switch. My xfire is a 2005 roadster. Can someone provide a link showing the removal sequence? Do I have to remove the lower removal dash panel to access the connector for the switch assembly?
Thanks, Jack
