Old Oct 13, 2021 | 02:31 PM
Jack G's Avatar
Jack G
Default Re: Multifunction Turn Signal Switch Replacement
Thanks dedwards. The section of the manual you suggested didn't go into the detail about having to disconnect the lower dash panel to access the connector for the multifunction switch. I also found the cable tie wrapped in 2 places. Once I was able to access the connector, disconnect the switch connector, and cut the tie wraps, removal was very easy. Before I lowered the dash panel I found a small light duty spring laying on the floor carpet. Now I have to search for where it might belong. If anyone knows where it belongs let me know.
Thanks
