Old Oct 13, 2021 | 02:57 PM
Jack G's Avatar
Jack G
Default Re: Multifunction Turn Signal Switch Replacement
Thought the same thing but checked the original with the new switch, the spring is there. The spring I found is approx. 1"long x 3/16" in diameter. It is light duty tension type spring with minimal pull resistance. I noticed the release lever used to adjust the steering column position has a spring connected to it's mechanism. I am wondering if this might be where the spring I found needs to go.
