Old Sep 21, 2006 | 04:07 PM
  #384 (permalink)
skr's Avatar
skr
Default Re: Sprint Booster - A "Must-have"!
I just installed mine, and I have a few comments on my 2006 MB C230 ss install:
1. The pedal came off fairly easily, had to pull the bottom of the assembly up and out first (kind a like you are rotating it out).
2. Once the pedal was out I had an extremely hard time getting the connector off my pedal assembly. I ended up breaking the tab that holds it down on one side. This part alone took me about 15 minutes and a few grey hairs to complete.
3. Finally, putting the assembly back in place was a major pain as well. It very hard to get it in the right position, so that it would hook-up at the top, since that area is concealed.
Once everything was put back together, I took it out and can notice a difference in the way the car was behaving. It is definitely peppier. I had always noticed a lag when I tried to accelerate hard from a stand still, after I put the SB in the lag is still there, but not as bad as before. I was hoping to get rid of the lag altogether, however, the overall behavior of the car is improved. It is not so sluggish anymore, and it responds as it should have originally from the factory. I consider this not so much a high performance mod, but a correction of a design defect from the factory.
Timelord, thank you so much for all the time and effort you put in for this group buy, and especially the quick turn around once you received it. I am also very appreciative for all the info that I received about the product from the forum as well.
Thanks again,
SKR
