Manual transmission won’t go into gear when car is on
Hello everyone, I am seeking advice about my base 2005 crossfire with the 6-speed manual. When the car is off, I can cycle through the gears with little to no resistance. However when the car is started, usually just first, but sometimes all gears refuse to go in. Most times I can shift into fourth then first and the car will be fine. Others I have to keep the clutch depressed for several seconds, then it will accept first gear. I do not know if this is a crossfire issue or manual transmission issue, but it is starting to become undrivable, despite shifting completely smooth after getting it going.
other information: 2005, 97107 miles, I don’t believe the transmission has ever been serviced in any way.
if you have any questions please ask, I need help!
