Disassembling a Headlight
I am curious to learn if anyone has successfully opened and reassembled a headlight assembly. If so, what was the procedure used and the level of success. I recently watched a YouTube fast forward demo of a Russian guy opening up a xfire light assembly. It was difficult to see or follow any of the difficulties involved with doing this. They used a combination of cutoff wheels and heat to separate the reflector half from the lens. My main reason for doing this is to clean the inside surface of the lens. Before attempting to separate the assembly I will try the solvent coated pad and magnet technique. Accessibility is the only constraint when using this technique.
