Thread: Ashtray Fix!!!
Old Nov 6, 2021 | 01:46 PM
DarthW's Avatar
DarthW
Default Re: Ashtray Fix!!!
I had the 'same' issue with one of my Crossfires in which, unfortunately, the 'hook' mechanism for the Ashtray broke, thus, the 'repair' as already posted in this Thread was my best course of action. I took some pictures of my process as it may help with regard of the pieces of the Ashtray unit. My main concern was whether or not the 'middle' piece where the airbag light is on for the US Crossfire Versions as well as the cigarette lighter could be 'transfered' to a 'new' (though used) replacement unit that may or may not have those pieces in the set. These pictures will definitely help those users to clear those questions:
(If you can't see the pictures, then you may need to be logged on in the forum first. The pictures are in full size as I wanted to post as much detail as possible... as in my case, when researching this issue, I stummbled upon this thread, in within other postings as well, and used every bit of information to determine which way, if any possible, could be the best course of action to 'repair' my Ahstray Assembly for the Crossfire)
Chrysler Crossfire Ashtray
Chrysler Crossfire Ashtray - Detail
To remove the 'middle' and cigarette lighter section do as shown in the following pictures:
Remove the back 'clip' found on the back of the Ashtray unit
