Thread: Ashtray Fix!!!
Old Nov 6, 2021 | 01:59 PM
DarthW's Avatar
DarthW
Default Re: Ashtray Fix!!!
Once the 'middle' section and Cigarette lighter assembly unit has been removed, then, if needed, it can be further disasambled:
-you can use a screw driver as seen in the pictures below to press down on the locking plastic clips found on the top and bottom to unlock it and be able to remove if from the frame that is mounted on
Repeat the same process on the bottom clips:
Once completed, then the entire front-end part that hold the 'middle' piece/plate (where the Airbag light is for US Crossfires) and the Cigarette Lighter will be removed
