Old Nov 6, 2021 | 04:46 PM
amx1397
Default Re: Orlando speed world tonight 10 27 2021
Originally Posted by JoeO
ZOOM !
just emailed to all my high school buddies. They’ll just die.
I was the one with the Rambler in HS
i had a 51 nash rambler, in high school,,, then things happened racied for AMC 69 to 71 with a AMX,, OH amx1397= amx the car,,,,1 for the first amx amc sold... 397 for three hundred ninety seven amx's i have owned. that plus this below is why i rebadge my crossfires AMX
______________________AMX________________crossfire ______________
Seating Capacity______________2___________________2_______ _________
Wheel Base__________________97"_________________94.5"___ __________
FR.Track____________________59.7"________________5 8.3"_____________
R.Track_____________________57.0"________________5 8.2"_____________
Length______________________177.2"_______________1 59.8"____________
Height______________________51.7"________________5 1.4"_____________
Ground Clearance____________5.29"________________4.9"____ __________
Curb Weight________________3035 lbs._____________3084 lbs.__________
Weight Distribution F/R,%_____57/43________________54/46_____________
Trunk Space cu.ft.____________9.6__________________7.6________ ______
Turns Lock to Lock____________3.8__________________3.1__________ ____
Turning Circle________________33.5'_________________32.9__ ___________
Engine Compression Ratio______10.2:1________________10.0:1__________
SAE. H.P.____________________225__________________215__ ___________
Frontal Area sq.ft.____________20.6__________________20.6______ ______
Final Drive Ratio_____________3.15:1________________3.27:1____ _______
Body Construction____________Unitized_______________Uni tized_________
Steering___________________recirculating ball________recirculating ball___
Braking 60-0 m.p.h.__________115'__________________114'________ _____
Automatic Trans. Performance__Motor Trend____________Motor Trend_____
30 m.p.h.___________________2.9 sec.________________2.5 sec.________
60 m.p.h.___________________6.9 sec.________________7.1 sec.________
1/4 mile time & speed_______15.2 sec. 92 mph._____ 15.18 sec. 96 mph._
Manual Trans. Performance____Car & Driver____________Car & Driver_____
30 m.p.h.___________________1.9 sec.________________2.1 sec.________
40 m.p.h.___________________3.1 sec.________________3.5 sec.________
50 m.p.h.___________________4.5 sec.________________4.7 sec.________
60 m.p.h.___________________6.6 sec.________________6.5 sec.________
70 m.p.h.___________________8.5 sec.________________8.2 sec.________
80 m.p.h.___________________10.7 sec._______________10.2 sec._______
90 m.p.h.___________________13.5 sec._______________13.1 sec._______
100 m.p.h.__________________16.3 sec._______________16.1 sec._______
1/4 mile time & speed_______14.8 sec. 95 mph._________14.8 sec. 96 mph_
Modified ??? vs SRT-6_____13.18 sec. 107 mph.______13.3 sec. 107.5 mph___
thanks for these specs (fireamx)
now you know the rest of the story (steve harvey)
