GraphiteGhost
42 degrees F in the garage this morning, checked tire pressures with my 'tire pressure gauge' and found all 4 of them 4.5 lbs low. During my pre sunrise jaunt felt the 'wobble like' crawling while driving down the road. Later this morning, filled all 4 to two pounds above OEM rates (34 fronts, 35 rears). This is and was in anticipation to the much lower temps as winter months are almost upon us. After filling tires, WOW... Super fast (no lag) steering and dang if it felt the car was brand new again!
OK, enough, PSA time... Check your tire pressures if this time of year means lower temperatures! Have fun!
copperfieldkid
The door placard on my SRT states 36 PSI Front/Rear
The difference is interesting, if anyone knows the reason share with the board.
I just checked the tires on the Crossfire and found them about 2-3 lbs low due to temperature drop. Pumped the tires up to 36 psig, which is what I've used since I bought the car back in OCT/2008.
