Old Nov 18, 2021 | 12:31 PM
  #7260 (permalink)
GraphiteGhost
Originally Posted by SD Crossfire
I just turned off my TPMS light and now use a much better aftermarket TPMS that has very accurate sensors mounted on the valve stems as a cap replacement. The head unit is small and solar powered, shows not only the current pressure in each tire, but the temps as well. You can also set alarm/warning for both pressures and temps to whatever level you want.
The whole kit cost $50 and took 3 minutes to install and gives so much better information than the factory TPMS.
Yeah, I saw a post with that a while ago, they look like a great system and like you said, only @ 50 bucks. I wonder if those states with vehicle inspections would accept them? Giving the exact pressure (checked every once in a while with a tire gauge, for accuracy) would be great for someone like me but I still would use ole reliable! LOL
I also saw someone post that said something like 'the sensors on his system were stolen' (even though have a locking nut system to stop that).
