Old Nov 24, 2021 | 02:47 PM
  #56 (permalink)
amx1397
Default Re: List of knowledgeable Crossfire repair shops
Originally Posted by Connie Loudermilk
I need someone who can troubleshoot/ repair near Huntsville AL, replaced ECM and TCM, still have to manually release the shifter. Any ideas?
checked with Miamimatt the travling crossfire mech . text him then he will get back to you 786 877 5959
first do u have brake lights? if no replace your brake light sw -------if that does not fix it, inside the shifter there is a plastic piece could be broken, when that brakes and once it does brake you can not remove the shifter out of park except using the release if those things do not fix it text matt see when he will be in Ala.
