Old Dec 6, 2021 | 09:16 PM
Jammer24's Avatar
Jammer24
Default Re: Front and rear spring removal procedure write up
i know this is an old thread and i just finished changing my control arms. If you tighten the control arm bushing bolts prior to having the suspension loaded, your new bushings won't last long. Load the suspension at ride height before tightening them. other wise you will twist the bushing when you jack up the arm to compress the spring.
