Old Dec 10, 2021 | 12:24 AM
onehundred80
Default Re: Transmission 13-pin connector
Originally Posted by roychez
My xfire went into limp mode so i did the dirty task of replacing the the conductor plate and 13 pin connector. Everything went fairly smooth until I tried to remove the TRANSMISSION 13-PIN CONNECTOR ADAPTER PLUG.
It's stuck Im not sure if I need to get a rubber mallet and pound it out. Any help or advice is needed. Thank You
From your vague description I am guessing you mean the white part that is held in with a bolt and then turned anticlockwise to remove.
Look in the “How to’s” forum for the thread “Index of Crossfire …..” in the transmission section for videos.
