Fancyface831
When I start up and go its fine for a minute. Then it starts getting sluggish and sputter. If I go at a high rate of speed it doesn't do it. At the light while I'm idling it runs rough.
What readings do you get from the O2 sensors?
I have had similar symptoms with a failing fuel pump, from a cold start the rich mixture was fine but when it warmed up the leaner mixture was not rich enough to keep the engine smooth. I do not think it would run smother at higher speeds though. The fuel pressure was under 10 psi.
