Re: I search beta testers for the Skreemulator
Thank you again for your reply, I have purchased 2 complete kits (ECU, SKREEM, key and ignition) and both have not worked...So, I am beginning to think there must be something else...You say look at the "RCM" ...not sure what that is...I have replaced the relay control module (RCM ?) if that is what you mean? I can try another one...but it came off a working car and I think it is good, I have forced the fuel pump and the starter to crank by shorting one leg of each of the relays...Anything else that I should look at or anything on the RCM that would affect the ECU ? Thank you again...LP
