Old Dec 28, 2021 | 12:21 PM
FloridaCrossfire2006's Avatar
Default 2006 Crossfire P0425 Code
Hello Again,
So I fixed the P0410 code by changing out the little blue one way valve on the secondary air pump system. Now I'm getting a P0425 code. This car sits a lot and I think that's part of the problem, it needs to be driven. Anyway, what do you guys suggest I do? I was thinking go out and drive it and get it hot maybe the code will just go away lol, wishful thinking I know. The code says:
Causes
Possible causes of OBD code P0425 Chrysler
– Open or short in the optical sensor circuit – Optical sensor connector – Damaged optical sensor – Damaged PCM or ECM The Error code is generally activated on detection of the following conditions: Some high resolution pulses are missing from the optical sensor to the PCM
Possible Solutions
– If damage, repair optical sensor circuit – Replaced optical sensor – Replaced PCM or ECM
Thanks,
Frank
