Old Dec 29, 2021 | 07:45 AM
Viper-666's Avatar
Viper-666
Default Re: I search beta testers for the Skreemulator
Yes RCM = relay control module, have you checked the fuses on the RCM and the fuses in the black box (driver side) under the engine hood? You have changed the ignition switch? And the ring antenna? Have a look on the plugs of the skreem and ecu are there corrosion, bad cables.
Have you experience with a multimeter?
