Re: I search beta testers for the Skreemulator
If the immobilizer isn't deactivated the ECU will not control the ignition coils and the fuel valves and also not run the starter. And the skreem is only for sending open/close to the bcm and send the code for the immobilizer off over CAN-Bus to the ECU.
PINOUT Skreem, you can see the pin numbers on the plug (Pinout is for Crossfire or latest SLK R170).
Pin 10 -> 12V switched
Pin 16 -> Ground
Pin 18 -> 12V continius
