Thread: Brake Concern
Old Jan 10, 2022 | 08:24 PM
TearlessTom's Avatar
TearlessTom
Default Re: Brake Concern
Originally Posted by crowz
The only way I could see the pedal going to the floor like that is from a bad master cylinder if the fluid level isnt going down.
That is a possibility I guess but I was taught that a master will leak down under pedal pressure slowly. This does not once it pumps up it is fairly stable. I was also thinking it may also be a frozen caliper by rusting due to the high humidity in the area. Things rust fast here.
