Old Jan 13, 2022 | 08:15 AM
Theodosia's Avatar
Theodosia
Default Re: Clunk pressing in clutch while in first.
Thank you for the info. It is reassuring that it is a "common" issue. It does seem to go away after the car warms up a bit. The shift is tough and the noises are there when it is cold, but eventually smooths out. I'm still going to try re-greasing the u joints and drive shaft to see if that helps. I'll let everyone know if does. Thanks for your time.
