Old Jan 14, 2022 | 10:07 PM
Texas Thunderman's Avatar
Texas Thunderman
Default Re: Transmission issues
I bought a 2005 XFire sport coupe about 3 months ago. Found this forum right away.
About a week ago, the transmission started to drop into "safe" mode, where it won't shift above 2nd and limits speed to 35 mph. Thanks to this forum, I knew about the leaky electrical connection on the transmission. Checking under the car, yes, it was leaking xmssion fluid -- that I knew would be brown instead of red thanks to the knowledge I found here.
Pouring through the ample documentation on this site, I found that I could attempt the job myself. I chose instead to find a MB certified shop and with what I gleaned from this site, directed them on what I wanted done to repair the car.
I was right -- the xmission had lost at least two liters of fluid, causing the safe mode. The connector was leaking. They also found that the transmission gasket was also leaking. It was nearly three liters of ATF low.
Bottom line, $675 and it's fixed. Seems worth it to me. No other codes came up and it's good for another 100,000 miles. And it drives.
