Old Jan 15, 2022 | 03:21 PM
abergero's Avatar
abergero
Angry FAILED - Using steam tool to fix sagging coupe headliner
Good morning Crossfire enthusiasts! My 2004 crossfire coupe recently started showing a sagging headliner, on the forum I’ve seen several videos of how to replace the headliner and it looks like a lot of work to get it out of the coupe. So I thought of getting a hand held steamer to see if I can get the glue to re-stick once again to the headliner without applying any glue or spray. Unfortunately my headliner is sagging way too much and my outcome was not good. With light to heavy steam applied I was unable to get the glue to loosen up enough to re-stick itself to the headline. Maybe this would work well if you have a much smaller section. Was worth a try and wanted to share with you all. Has anyone had success using this technique? Cheers!
Steamer
Steamer
Headliner
Headliner
At work
