Old Jan 20, 2022 | 09:28 AM
onehundred80
Default Re: Windshield washer pump...low output?
Originally Posted by JBRDH
Any have this issue? Fluid dribbles out of the nozzle... no other apparent leaks noticed... Nozzles appear to be clear of obstruction...
The nozzle opens by unclipping it using the tab on it. This exposes a ball shaped nozzle that comes out, do not drop it. The hose and ball are probably plugged with gunk. Pump some washer fluid through the hose using the end **** on the stick. Clean the hole in the ball and reassemble, align the jet with a pin in the hole in the ball.
Do not use plain water in the washer reservoir as it turns slimy.
