SD Crossfire
I did the exact same thing a few months ago, installed a fresh steering damper. It was a little scary when you have to turn that steering wheel while on the Rhino Ramps, but it worked out, turned it just enough to get to that freaking nut. I considered turning it upside down, but then realized that bolt is located in that position so it doesn't fall out should the nut work its way out.
I am using the 16,000 lbs rated Rhino Ramps since I originally bought it for my RAM Rebel truck, but really happy with the durability, especially when having the turn the steering wheel with the front of the car on them.
In your opinion is it a job best done on jack-stands instead of ramps then?
