Old Feb 8, 2022 | 07:06 PM
  #1367 (permalink)
FlyingBoat's Avatar
FlyingBoat
Default Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Originally Posted by Ms Kitty NJ
Sounds like crankshaft position sensor. Experienced the same with my 07 Crossfire. My 08 appears at this point in time to be the "mystery no start" had the board
repaired and needed a new transistor relay. So far so good. The mystery not start the vehicle won't crank not a sound. All the electrical items works. The dash lights
up like a xmas tree! The only thing they could read as a code was power failure. Maybe check the SKREEM. Best of luck.
So if I am understanding you right, the "mystery no start" (repaired by doing this RCM replacement), is the case where the engine doesn't make a sound at all. Is that correct?
I thought I read here as well that the crankshaft sensor also doesn't make a sound when trying to start, but you are saying on your 07 that it did start to make a vroom sound and then die quickly, and it was your crankshaft position sensor? Just verifying this is what you are saying. Thanks.
Edit: I am pretty sure mine is the SKREEM issue. First and second time, tries to star and shuts off, third time nothing. Disconnect battery, wait a bit, reconnect, rinse and repeat.
Only two things cause me to question this.
1. I had hit a curb two blocks before I got to the parking lot. (Didn't notice having any problem getting to the parking lot after I hit the curb.)
2. Within a few seconds of stopping the car, before getting out of the car etc., I tried to restart because I had forgotten something at home. It was on this restart where the problem happened.
So, perhaps this is a clue to what causes the SKREEM issue? Bump or immediate restart?
A third thing. I just started to have the sticky key issue. Never noticed it before brother in law had it happen to him driving my car a couple of weeks ago, and it has happened to me twice now while trying to restart. This may be a particular key fob though. Today when testing it did the two try to start then stop. Third try I couldn't turn the key. Took my other key and it turned, but with the nothing happens result.
