Oil Cooler Gasket Leak
~ I have reason to suspect an oil cooler gasket leak.(Blk SRT-170Kmi.) I have seen a gasket on parts sites described as upper. Some of the gaskets are oval and some look round in the pictures provided on those sites. I have also seen a "kit" containing three gaskets for around 25.00. The leak has spoiled my supercharger belt leaving it "sticky". I pressure washed the engine and the underside and cleaned the belly pan. Underside of the engine cover shows small particles of what I think to be disintegrating rubber from the belt.
~ Have any members here had to change these oil cooler gaskets in the past? Any caveats? I have not yet searched the PDF of common repairs by 100. Rob suggested to check all pulley bearings while I am in there as I believe they are all original.
