Re: Oil Cooler Gasket Leak
Your going to want to replace all 3 as nemiro said. No point in only changing the 2 on the oil cooler. Also the easiest way is to remove the big 48 nut that holds down the oil filter housing. Then you can easily disconnect the coolant lines to the oil cooler and use a torx to remove the oil cooler from the oil filter housing.
