Re: Humor and Clean Jokes
Tools
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that t smacks you in the chest and
flings your beer across the room, denting the freshly-painted part which
you had carefully set in the corner where nothing could get to it.
WIRE BUFFING WHEEL: Cleans paint off bolts and then throws them
somewhere under the workbench with the speed of light. Also removes
fingerprints and hard-earned calluses from fingers in about the time it
takes you to say, ''What the...??''
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the
conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside
the wheel hub you want the bearing race out of.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack handle
firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward
off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit, that snaps neatly off in bolt holes thereby ending any
possible future use.
BAND SAW: A large stationary power saw primarily used by most shops to
cut perfectly good sheet stock into smaller pieces that more easily fit
into the trash can after you cut on the inside of the line instead of
the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength
of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
inexplicably has an accurately machined screwdriver tip on the end
opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids
and for opening old-style paper-and-tin oil cans and splashing oil on
your shirt; but can also be used, as the name implies, to strip out
Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, nowadays the hammer is
used as a kind of divining rod to locate the most expensive parts
adjacent the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on contents such as seats, vinyl records, CDs and DVDs, liquids in
plastic bottles, collector magazines, refund checks, and rubber or
plastic parts. Especially useful for slicing work clothes, but only
while wearing them.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage
while yelling ''DAMMIT'' at the top of your lungs. It is also, most
often, the next tool that you will need.
