Todays progress was pretty good.
The 90 degree drill I ordered came in and the wiring harness adapter.
First I drilled out the holes to mount the double din cage.
Next I put the screws into the cage mounting it.
At this point I didnt like how tight the radio was against the screws I had on hand so Im going in the morning to get new ones at the hardware store. So I finished wiring the plug I ordered and connected the stereo.
These shots are with it playing but not in the sleeve as it was so tight I was worried it wouldnt be removeable if I forced it.
Its connected to the usb stick George had installed for the old alpine radio. Since I like some of the same music too Im leaving it for now
I was amazed that the gps antenna worked so well. The car is parked inside the garage right now so the signal has to go thru the garage roof and the dashpad of the car. Worked great. Showed my location and set the date/time for the stereo.
